The flashing light denotes a TPMS system problem; it may not necessarily be with the sensors themselves. Early Versas are subject to Nissan Service Bulletin NTB06-78a, where if certain codes are generated along with the flashing TPMS light, the Body Control Module (BCM) must be replaced.Johniboi wrote:Anybody wanna confer this? Just to make sure...
Im not really trying to go to the dealrship..i hate that place,any way for me to get rid of that light or fix it at all?
Most shops charge using a flat rate manual (e.g., says that doing Task A takes 90 minutes). The flat rate manual is usually pretty conservative, and most mechanics beat the time by a considerable extent. I'm guessing the flat rate manual shows an hour for resetting the TPMS, and that's what they'll charge you for.darkwind25 wrote:They are hosing you,,It dosen't take an hour to reprogram the TPMS,,,,it takes about 20 mins to do it,,,,and I'd let them know that too.
My Versa is not that smart. It just tells you one is low. You have to find out which one yourself.darkwind25 wrote:
If you put the rims back in the same hub,you won't have to reset anything,but if you rotate them ,you will have to reset.As far as the car is concerened.If you have one on the right frt and move it to the right rear and not reset the sensor,,,,something happens to the right rear.It will tell you it's the right frt that has the problem.Cause the sensor still thinks its on the right fr.
BUt whern they connect the consult up to the car it will tell them which tire sensor is giving you the light,and repair the tire as necessary.As for flat rate. most the times its way out of whack.Theres noway it would say an hour to reset all TPMS's ,hell even under warranty its only .3 to do it.scar wrote:
