wierd problem s13 with rb20
fast_s13
ok so the first ten or fifteen times the car started it would shut off just fine..now when you shut it off something is back feeding and keeping it running for a few more seconds... i unhooked the green ign reley and it will start up and shut off just fine.... any one know what could cause this
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
When mine did that, it was because I accidentally wired the rear window defogger into the ign. :D
fast_s13
every thing is wired correctly..this is the second rb swap i have done
fast_s13
nobody?
jrb92se
Car: 1989 Nissan S13 coupe
preignition or run on; the timing is effed
fast_s13
it is backfeeding powering the ecu after they key is turned off
jrb92se
your timing is advanced to much you need to retard the timing , also does it run hot? sometimes if an engine is too hot or has spots on the cyl head this will happen ,could be carbon build up too , id get someone to check your timing first
