Darius wrote:It's definitely more difficult to get exhaust gases to pass through a seized turbo so it's causing more exhaust gases to go through the good turbo and increases the load on IT. Probably get some damn quick spooling on that one turbo though
And yeah you're probably right about the difference in MAF readings causing problems. Replace the turbo and you should be good to go.
Correct me if I am wrong but a stock rb26 twin turbo has a split exhaust mani, meaning 3 cylinders feed the front turbo and 3 cylinders feed the rear turbo. If one seizes, there is no sharing of load. Instead, you basically shut down half of the engine. Unfortunately, the other half is still running so the "dead" cylinders are stroking with no exhaust path except thru the wastegate. If the wastegate is closed (i.e., boost controller installed backwards), the overcompression could lead to a blown head gasket or more catastrophic results. I would check the engine closely before simply replacing the turbo. At idle, the turbo may allow some flow but, even if totally blocked, the wastegate would open if the blocked flow begins to build pressure and you probably wouldn't know that it is open.
