WIERD power window problem?
BoRkA
I have a 1991 S13 coupe and my driver side windows has a very wierd problem it only works when the weather is warm out side... so when its warm and the sun is shining at the door the window will work perfectly. now when it gets to evening time and it gets chilly outside the window would just stop working i mean wont do anything like its dead.
any thought are highly appriciated.
yellow_jacket
Car: 95 240sx
You will have to pull off the door panel one day when it is not working and check to see if the window motor is getting power. If the motor is getting power then the motor is bad, if it doesn't get power then it could be a couple of things(the most likely being the switch).
