wierd noise!
gehzumteufel
Car: 1992 240SX with fidanza flywheel, clutchmasters clutch, B&M shifter, soon ksports & rucas
just this past fri i started hearing a wierd *** noise. a squealing when accelerating. it doesnt do it any other time. i will be replacing both belts on tuesday after work when ill finally get time before its dark. what else could this be other than the belts? thanks in advance.
slipnfall
Car: '06 D40
Unlikely the belts themselves-I wouldn't replace them if they are in good condition. Low belt tension can cause noise. Check the deflection of the belts before replacing them: for Alt/PS, you should only be able to push the belt up and down about a 1" range.
FYI having belts *too* tight can prematurely wear shaft bearings in the accessories(alternator, power steering, AC compressor), however this would likely be a continuous squeel once they go.
Umm, clutch fan can make some nasty noises when they go bad.
M/T? A throw-out and/or pilot bearing can cause this, as well as input bearing to bellhousing.
Don't rule out power steering. :-)
I have a squeel that pops up every once and a while, I can't seem to get it to go away: I didn't bother replacing the pilot bearing when I put the new clutch in, and I think this is my problem.
HTH-Slip
gehzumteufel
whats the best thing to check first? i have never replaced the belts since i have owned the car and they have been on there for a bit and look a bit worn. so im going to replace them anyways. since it exhibits crappy acceleration i was thinking it had something to do with the clutch. whats the easiest way to figure out what part it is? btw mine is m/t and according to my buddy i bought the car off of got a new clutch 2 months before i bought it so the clutch is 8 months old. i am unsure if he resurfaced flywheel or replaced the bearings. didnt ask. will find out though.
slipnfall
Car: '06 D40
Well since you need belts anyways, go ahead and replace them... the alternator belt is kind of a pain to get to from up above BTW.
See if that helps first.-Jamie
USDM240
Car: 1993 Nissan 240SX Limited Edition 'vert
the belts or the throw-out bearing would be my guess.
gehzumteufel
well it appears its coming from the transmission area. so i am now going to save and get a whole new clutch and flywheel. get rid of the **** and get better stuff.
slipnfall
Car: '06 D40
Well if you do, make sure to replace both the throwout bearing and the pilor bearing. Lube them and the slave fork up real well w/wheel bearing grease(lithium-based) before installing also. Otherwise you'll be back at where you started.
