wierd noise from back tires???
kdub41
Car: 1993 nissan 240sx se hatchback
ok so i just bought this 93 240 hb with a 2 way limited slip but when i make like slow turns it makes a popping noise where the rear tires are and its loud any idea what it could be??? please help
rsdans240sx
Car: 1990 240sx KA
Sounds like your lsd might be going out, when my friends was going out out it would make weird popping noises whenever he made slow turns.
nismoracingsx
Car: 1993 White 240sx Coupe
pull the pan and take a peek , rear ends are simple to service
240sxbuffy
Car: 1989 240sx
drain fluid from rear diff add good fluid a LSD additive go to dirt parking lot drive in figure 8's for about 15 minutes SLOWLY if this doesn't help needs new cluthes in diff.. Good luck
spindrift187
every 2 way ive ever heard/owned sounded like that.
