wierd noise coming from transmission
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
i have some strange noise coming from my transmission, its there at idle and its there when in gear, when rpm's rise the noise increases, when i depress the clutch the noise goes away though... the noise sounds like something rubbing against something, like metalish rubbing sound but very light rubbing..
thats the best description i can think of..
:help max
edit: o yeah i put redline mt-90 in yesterday, it wasnt making the noise right after that... and i filled the fluid up to the fill plug (~2.5 quarts)
blackbeauty240
Car: cooking, fiddeling around with different cars
its probably the throw out bearing going bad
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
a throw out bearing huh.. is that in the transmission? and what does it do? should i be running around screaming or can i drive my car still? :eek:
tnxMax:)
BurntClutch
Car: 91 240SX Fastback
The throwout bearing is in between the engine and transmission. Its the part that disengages the clutch. I doubt its that if transmission oil made the sound go away. I've had the exact same noise for months now and so far its just a nuisance.
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
well it wasnt there b4 i did oilchange.. It came a day after i changed the oil.. and i think it went away now, cause i drove it again today and i didnt hear it.. :confused:
o well..
max
