wierd noise coming from rear wheel area
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
i have a wierd noise coming from the rear wheel area, not sure which one, but its a squeaky noise like the caliper was warped or something, it is a squeaky brake sound and as i go toward 10mph it gets faster (so its something rotational that has to do with the speed) after 10 mph the noise goes away...
anyone got an idea what this one might be?
annoying :| :help
TIA
max
Ianfiniti
I had a problem sort of like what you're describing, and it was bad calipers, took me so long to fix it i had to replace the discs too.
VitaminT
Car: 93 240sx SE
Have you had your rims off lately? Sometimes the dust shields for the rotors will get bumped and start to make noises.
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
no i havent had the rims off.. i got the car a bit over a week ago, haven't really had time to do a lot to it yet..ill prolly jack the rear up when i change the differential oil and try to turn the wheels and find out where its comin from exactly
max
Zyphar
Car: 91 S13 5spd ! Stock, well almost stock.
make SURE your lug nuts are tightened properly. My car was making a wierd noise from my rear right wheel. I jacked the car and checked and nothing. But after i tighten the nuts and tried the car. it ran fine. so i say agian make SURE your lug nuts are tightened proplerly.
