wierd movement when accelerating.
Hb_Kidd
Car: 1994 Nissan Pickup aka D21/HARDBODY
1994 Hardd body pickup
Hi, When i push the gas pedel the back end of the truck on the passenger side tends to jerk. My front end of the truck goes to the left when if i dont correct it by steering more to the right. My truck is lowered 3 inches in the rear bout 4 in the front. I have stock shocks, crank torsion bars, rear bumper removed also. I might need an alignment but this issue just started to happen recently. Please help me out guys to figure out this problem.
Big-Bird
Car: 2000 Xterra on 'Roids & 2004 Quest SL
Sounds like either a broken spring(s), loose shackle, damaged bushing(s) and/or loose leaf spring U-Bolt(s).
Better get under there and start looking for loose or damaged parts.
Hb_Kidd
Thanks, i will check that first thing tomorrow. I was thinking the same thing its somthing def. wrong with the suspension. I was thinking a bad shock? But i will check all that you have mention. Any suggestions on some after-market drop shocks by any chance?
PEZi
out of curiosity... could it be something in the diff?
Hb_Kidd
Found out what the problem was!! It was a loose U-BOLT that was causing the axle to swing more to the right. The left bolts was so loose that i was able to unbolt them by hand. I think people with Lowering blocks should at least tighting them once every 2 weeks or so.
Big-Bird
Bang on baby! I love it when I'm right! It keeps a fellow NICO member safe and those on the road around him.
