Wierd ka24de problems
duveeka24det
Car: 240sx
I have a all stock 240sx except exhaust and intake...It acts as if it is missing but if I kink the gas line it runs smooth.....or if I switch the lines around it idles smooth but wont rev up...It's like if i slow the gas flow down it idles better......It's so wierd
timreaper20
Car: 1992 Nissan S13 240sx KA24DE
Well I hate to state the obvious, but it sounds like your getting to much fuel, bad injetors... faulty fuel pump... or it could have sopmething to do with your aftermarket parts, such as your intake or exhaust, none the less it's a weird problem
got chub
Car: pearl white 95 240sx
your mafs might be reading wrong... if you can change it our for a friends to check
Vegascorbin
Car: 1990 240sx dirt track race car
I agree with Timereaper20. Also check your plugs and wires. Too much fuel + weak spark = bad idle. Less fuel + same weak spark = good enough for Idle but no power.
While you are at it you may as wellcheck the fuel filter. Won't change anything but it is often overlooked. Dirty fuel can clog injectors and have them stick open resulting in too much fuel.
Dr.Doom
Car: 240sx s13 hatch
first, make sure that your fuel lines are hooked up correctly.then perform a tune up--wires, cap, rotor, spark plugs, fuel filter.if you still have a miss, then with the car running, disconnect each injector one at a time(unplug the connector). if the rpm doesnt drop or drops a lot less than the others, your problem is in that cylinder.if that doesnt present a problem, start with the simple crap...clean the maf, check your timing, check and make sure your tps is set correctly, check your iac valve(make sure it isnt stuck too lean)
duveeka24det
Car: 240sx
I swaped fuel rails with one of my buddies.. and it still does the same. so now I know it's not the injectors, fpr, or fuel rail.. I also changed the plugs and wires so guess I'll try that fuel pump...
