Wierd Grinding In reverse when wheel is turned to right
mickeyd420
Car: s13 92 se
This has been happening for a while now. Its not the gears transmission or such. It sounds like a scrapping grinding noise while reversing only when the wheel is in a certain position. My mechanic mentioned it could be the exhaust. I dont no what exhaust i have, im pretty sure its not stock and it shakes sometimes. do the kyg shocks have anything to do with that? let me know your thoughts i wanna stop this.
S13SR20
Car: 2007 350Z NISMO (#0592), 2003 Dodge Ram, Sold the 240's
Are you using factory size wheels and tires?
mickeyd420
Car: s13 92 se
yes
S13SR20
Have you looked for anything that may be rubbing? brake line, inner fender, ECT...
gthammers
Car: 1991 coupe, 1994 coupe
Check your carrier bearing bracket on the driveshaft. Mine did the same weird thing and this was the cause!
