onecrazyfoo4u »
https://forums.nicoclub.com/onecrazyfoo4u-u42462.html
Wed Sep 12, 2007 8:14 pm
So, I got a fuel gauge put on awhile back, and now I've put a nismo type A fpr so I can turn it down. My question is, at what engine temp do I adjust the fuel pressure? It varies quite a bit, at least on my redtop.
When it's a cold morning start, the pressure runs a little high, about 36psi. When I've run the car and shut down for a couple hours, it'll run right at where I set it, 34psi. And when I've run it hot for awhile, and the engines really hot, it'll be about 31psi. Is this normal, for the fuel pressure to vary with temperature? Just wondering what temp to set it at?
I'm still having cold start problems, where it's flooding every morning I try to start it. Could I turn the pressure lower then the fsm rated 34psi? If so, what's the lowest you can go without running the engine lean? Thanks!
