Wierd clutch problem
usbrother
Please, please, please, need help. Does anyone knows about this problem? After car stays 2 days or so the clutch activates with pedal all the way down. After driving ~30 minutes it activates when pedal is almost all the way up.New clutch and both cylinders. Appreciate any ideas.
s13sr20chris
thats wierd. im guessing its some sort of actuation issue like a pressure plate malfunction. do you still have the damper box?
yunkie
Car: 1993 240sx
I had the same problem after putting the engine and transmission back in my 93 240sx. I replaced the slave cylinder and clutch master cylinder and it still did it. It turned out I had a lot of air in the line and needed to adjust the rod on the clutch pedal.
NISTECH
yunkie wrote:I had the same problem after putting the engine and transmission back in my 93 240sx. I replaced the slave cylinder and clutch master cylinder and it still did it. It turned out I had a lot of air in the line and needed to adjust the rod on the clutch pedal.
Thats where I was going!
Welcome to NICO Adam.
