Wierd Clutch pedal Noise after removing Damper.
driftin8ez
Car: 92 Coupe, Turbo Miata
Ok here is the problem. During a high rpm shift the clutch pedal feels like it is rumbling or shaking and it makes a wierd kindof metal vibrating noise. It only started after i remove the clutch damper. Is this normal seeing as the pedal has more feel?
Soy
Car: '03 Mazdaspeed Protege #295
The damper is there for a reason - to keep it from doing what you described. :P So yes, I guess that could be called "normal"
James
driftin8ez
ok thanx, just wanted to make sure i didn't break anything.
