wierd clutch noises????
DaTt240kIdD
Car: 89 s13 hatch...ka24de...Sr20det swap soon
i was getting a skipping feeling when getting off 1st gear...i replaced my clutch and it was in peices so i thaught it was gonna fix the problem but it started doing it again the other day its not as bad but its still there...i was thinkin it was the throwout bearing but i couldnt use the bearing sent with the kit it was diffrent some how...if anyone has any idea what it can be ill greatly appretiate it...i have a 89 s13 ka24de with a transmission from a sohc by the way....email me at [email protected] guys and gals
Modified by DaTt240kIdD at 4:39 PM 10/8/2007
Modified by DaTt240kIdD at 4:42 PM 10/8/2007
DaTt240kIdD
DaTt240kIdD wrote:i was getting a skipping feeling when getting off 1st gear...i replaced my clutch and it was in peices so i thaught it was gonna fix the problem but it started doing it again the other day its not as bad but its still there...i was thinkin it was the throwout bearing but i couldnt use the bearing sent with the kit it was diffrent some how...if anyone has any idea what it can be ill greatly appretiate it...i have a 89 s13 ka24de with a transmission from a sohc by the way....email me at [email protected] guys and gals
bump...
DaTt240kIdD
bump....
DALAZ_68
Car: 90' 240sx CA18det
could be over tightened preaasure plate maybe...did u torque to specs...
hmmm could be ur throwout bearing...just im not sure by ur discription of it...
DaTt240kIdD
DALAZ_68 wrote:could be over tightened preaasure plate maybe...did u torque to specs...
thanx...what are specs by the way??
WWJD
did you resurface your flywheel?
did you put in a new Pilot bushing?
did you get the right kit? since your TOB is different?
