wierd clicking from cam shaft area
spitz7985
Car: HICAS S13
my car recently began making a weird clicking noise from just under the valve cover. it is constant, sounds like one cam lobe is smacking the bucket really hard (but that can't be it). it doesn't sound like bad lifters.when i took the valve cover off, i couldn't see anything wrong but i did notice some wierd *** nicks in the shaft between two lobes. i don't remember those being there but they could have been. they were like five dents equally spaced apart. i dont know what they are or what they're from or if they have anything to do with the clicking. the rest of the shaft is undamaged and there's no loose piece anywhere.any ideas?
allthrottlenobottle
Car: 91 s13
timing chain guides gone maybe?anyone?
spitz7985
Car: HICAS S13
nope, replaced those in july.
the noise started right when it started getting cold. probably just a coincidence, but maybe it's a factor.
themadscientist
maybe time to re-evaluate your oil viscosity, the temperature change seems to have started this right?
chmercer
thread hijack, sorry :p themadscientist, could you post some pics of your cars? i would like to see a clean r30 :)
allthrottlenobottle
Car: 91 s13
good point on the oil viscosity madscientist i always run 5W30 but the climate where i live fluctuates so much so i always run 5W30. spitz7985:what type of oil are you using?
spitz7985
Car: HICAS S13
5W-30 during the fall/winter
themadscientist
It's a KA I assume:confused: If it's got hydraulic lifters one may be bad, I had a bad lifter on one of my RBs that would periodically bleed down and clatter. I use Mobil 1 15W50 exclusively but it is consistently hot as crotchpot cookin round here so I don't have to go light in the winter.
"clean R30" you don't want to see mine, it's rusting to the ground:( I deserve a sound spanking, any NICO cuties up for it?
I scrapped my Silvia and I will be scrapping a rattletrap R30 soon. That leaves me with an RX7, my rusty R30, my bike and a recently aquired GTS-T. I am getting a Haltech to fire up the 7 so I can get it sold and the GTS-T is a solid daily driver so by summer I hope to be knee-deep in the resto of the R30
ricebike
2002 Quest
2005 Altima
"1991 240sx "= a DOHC engine... u got shims under those cam lobes/ no hydraulic lifters... can't help u more there... maybe others in the "KA24E & KA24DE" engine talk boards can shed more lite on this...
