trpower7 »
https://forums.nicoclub.com/trpower7-u205.html
Mon May 19, 2003 4:25 am
The Z32 rear end bolts in to all model 240s, you need to swap the rear cover and the output shafts. For example, if you want to put a Z32 LSD into any 240 you must get the appropriate year 240's LSD output shafts. They are something like $95 a piece from Nissan or you can junk around for them. But if you find them, you just found yourself a 240 LSD anyway, so what's the point. There is a full writeup on a 300ZX LSD install on wwww.240sx.org
