d k wrote:So running the 9.5's in the front and going wider with a spacer, is it feasible to be able to run a 10" wheel in the front??? ($1,000,000 question).
My question is why do need 10' wide front tires on your 240? Are you running some sort of AWD system?
Larger tires and rims result in more parisitic drag and it robs power from your car.
Also if you run 10' wide stock (rolled and pulled) front fenders then you will only pull it off by useing smaller and smaller rubber. A 9.5 with 255 will work but 10 will need 245 and this will decrease your rubber contact patch therefore decreasing potential traction.
Any one else feel this way or am I the only one?
