rb25xtc »
https://forums.nicoclub.com/rb25xtc-u10213.html
Sat Jan 12, 2008 4:48 am
Taken from Innovate Motorsports website:
Install the oxygen sensor’s bung upstream from the catalytic converter. The bung must be installed in the exhaust pipe at the side or ontop, NOT on the bottom of the exhaust pipe. Best position is between 10:00 and 2:00 position.
On TURBO CHARGED vehicles:
Install the bung downstream from the turbo before the catalytic converter. The high exhaust pressure before the turbo interferes with the lambda measurement and the high exhaust temperatures encountered there can damage the sensor.
Do NOT install the Bung below the 3 o'clock or 9 o'clock position.Condensation can form in the exhaust pipe and permanently damage the sensor. 6 o’clock is the absolute worst position to mount the sensor.____________________________________________________________
Anyway, you want the sensor 18 inches or more downstream from you turbo or collector. Too much heat will shorten the life of the sensor. Here's where I installed my Innovate O2:
