Wideband?
240SXer
Car: 1995 240sx SE (2jz powered)
Okay, i'm going to be getting my GT25R on the stock fuel system. I was going to get it dynoed just to make sure the A/F ratio is good so I don't lean it out (running 7.25psi).
I noticed several places sell widebands for a decent price (AEM, http://www.ka24de.com, lsauto.com, etc). Are these widebands any good? It might be easier if I just got a wideband rather than spending the money to get it dynoed. I'm eventually going to get 740cc injectors and a retuned ECU, but that's at least a month away, i want to be able to drive it before that.
Should I get a wideband or just get it dynoed with A/F ratio?
Dori Dori
Car: Cars of course
Well you can't tune with a wideband...it's just a sensor w/ a meter/gauge. You'll still need something like an emanage/safc/standalone/exc. If you have one of those and just want a 'safe' street tune, than it would be wise to tune w/ a wideband. The problem though is that unless you have a datalogger too, you't won't be able to tune (or go to a dyno). If you have to go to a dyno anyway, they should have a wideband to hook up with.
Phax
Car: Control dynamics
I think that you're worrying way too much about running the turbo on the stock fuel system. It isn't going to be flowing that much more air than a T25 at similar boost levels.
f150intally
actually 7.5 psi on a t-25 vs. 7.5 psi on a gt25r will be quite different, but you should be fine on the stock fuel system. just have someone hookup a wideband on the dyno to check the a/f ratio.
240SXer
A lot of people scared me, I just don't want to lean it out. I guess i'll just go get it dynoed.
240SXer
It's $90 to get it dynoed with A/F ratio (HP and TQ). So I'm just going to do that...
Phax
240SXer wrote:It's $90 to get it dynoed with A/F ratio (HP and TQ). So I'm just going to do that...
Where are you getting it dynoed at? I want to get mine dynoed soon, and $90 seems like a reasonable price. How many runs do you get?
240SXer
It's $90 for the 1st pull, then $15 per pull after that. I don't know how good that price is. But it's okay with me. I'll probably do 2 pulls.
I'm in Lancaster, Ca. It's at RE Racing (re-racing.com) it's too far from you. I'm sure there are places a lot closer where you can get just as good or better pricing.
turboex
I uses a wideband on my setup for day-day driving and for street tunning. I have a plx unit, it was $32 and the install is a snap. It has both wide and narow outputs for diffrent gauges. I have it hooked to my greddy e-01 so that way if the air/fuel runs to lean ( a point that i set up) It instantly lowers the boost to what my wasgegate is set at, 4psi. Works great so even if i have an injector start to crap out on my im still on the safe side. Works great. Also these new wide band sensors are good for over 60,00miles daily driven as there stock VW parts. Just a little info fo ya
f150intally
did I read that right? 32 dollars?
240SXer
Where can I get a wideband setup like that?
TruboostPerformance
With that turbo and boost level you don't need a dyno tune, your stock ecu and fuel system can handle that, thats about like a T25 running 16psi, if you feel the need for comfort, get a wideband and a AFC and you'll be just fine
GTS4-R
Car: my feet
THREE LETTERS!!!!!!!
F J O !!!!Get it, love it, andnever regret it
240SXer
What's F J O? How si your car doing anyway 93Niss240? Any dyno? Races? Impressions?
B.L
The FJO kit is nice, a friend of mine has it.
I got the innovative lm-1 kit in the mail 2 days ago.Still need to install it though...
240SXer
humm.. Too bad I have no clue what FJO is
240SXer
Okay, I foud the FJOs.. Are they good? Seems like about 600 bux. Think i need data logging?
GTS4-R
Car: my feet
nuthin yet.....seems like whenever i fix 1 thing....2 things go wrong....1 step forward 2 steps back.....WTF!
240SXer
Damn.. the sux. How did your ROM from SS work? Any good? I w as going to get one from them for my GT25R
msaskin
Car: cars, computers, skiing, mountain biking
Best feature to price for a wideband is by far the PLX Devices range.
Get the M-300 if you don't need logging, or the M-500 (i think that's the #) if you want data-logging.
~matt
GTS4-R
Car: my feet
ya those are the cheapest (good value) but if u can splurge buy the FJO....it ownz....
The tune from SS is incredible....when the temps are right (75deg ish) the GReddy A/F reads 12.0:1-11.8:1 generally at full spool....thats near perfect....the safc is zeroed out...only thing is that Scott Avoy doesnt work for SS anymore....hes gone independant,,,noit sure if he still does the rom burning tho...he might....hes the man that pulls off the ill ecu tunes
240SXer
I'll need mine tuned for 91 octane.. I hope they still have something for me. I'm just worried that somthing will not work out right with it. Is there anyone left there that can still do a good job?
Nathan
Holy crap, 90 bucks for a dyno pull? We get 3 for 40 around here...sometimes even cheaper!
bootman
turbo xs tsx it is the s*** has a/f datalog & knock user friendly I have used one and like it alot am I going to buy
http://www.turboxs.com/txstuner.htm
240SXer
They're too far from me though. 90 is a lot.... I'll look for some other local places.
