480sx »
https://forums.nicoclub.com/480sx-u50548.html
Wed Mar 05, 2008 4:52 pm
Zeitronix!
Dude you will love this WB system. For 300 bucks you get the controller and the o2 sensor. They have accessories like a AEM style AFR gage, a LCD screen that displays all your vitals, and a warning audio/visual box that can be programed to go off whenever you want. It can also be hooked up to a engine kill solenoid, in the event that you over boost or your AFRs arnt within your set safety margin. Its completely programmable, with multiple variables, if/and situations, ect.
The zeitronix unit with a laptop will data log AFRs/TPS/RPM/EGT/Boost. It can also be hooked up to a 0-5 volt system. I use it for the maf sensor, it can also be used for a knock sensor, among other things.
It also has a 7 times faster data sampling rate than a LM-1.
I cant say enough about mine, it made tuning my brothers SR a snap. The data logging software is soo easy to use. I havnt really messed with it on my ka-t yet, but its in there doing its thing. Just have to hook up a wire to the controller, which is about the size of a credit card, and one inch thick.
IMO the AEM unit is a bust, 300 bucks and it just gives you a gage and a sensor. No data logging, or anything cool. LM-1 is nice, however last i checked the unit with all the bells and whistles is like 500 bucks. However, if you have a stand alone ecu with WBO2 support, the LM-1 has a new setup thats like 180 bucks that will just give a WB output to your stand alone. Thats the only way id use a LM-1. The PLX unit's are bulky, and expensive.
Check out their website, just google Zeitronix.
What is a WBO2 controller that requires calibration? I know that mine is auto calibrate..
As far as narrow band o2 sensor emulation, i have heard bad things about it across the board. From what iv heard the narrowband sensor does a much better job.
Also, as long as your WBO2 sensor is mounted atleast 18 inch's away from the turbo you can get 50k miles out of them or more so i have heard. The WB sensors are about 70 bucks shipped on ebay, the bosch ones.
