Wideband
surfwax95
Car: 1999 Mazda Miata
Alright, I've searched.
Newb question, I'm sure, but I am new to forced induction.
What is wideband and how/why does it work?
From what I've read I gather that it replaces stock O2 sensor (or wiring) and measures A/F ratio using exhaust, but how would this let you alter the A/F ratio (what's the point of having it?) Would you have to use electronics such as the SAFCII ?
Thanks so much.
D-UNIT
Car: a 91' S13 (15.014 @ 94.56mph NA) KA-T
http://www.ka24de.com/
Buy it. It's good.
Frozen240
Car: 92 240SX KADET
Go here
http://www.innovatemotorsports.com/index.html
and read everything three times over, then write your own description of how a wideband works.....you should know it by then
surfwax95
thanks for the link
foley
just like the name implies, it's a wideband 02 sensor. narrow band (stock) tells you rich, stoich, or lean, with no resolution. wideband tells you HOW rich or HOW lean.
surfwax95
Thanks for all the info, this should make a good search result for someone one day.
Mustangs_Suck
Just got my car wideband tuned 2 days ago. made a WORLD of a difference. no more smoking, no more rough idling...it's doing great.
I guess my AFR was 14.5:1 which is DANGEROUSLY high. Set it down to 12.5:1 and she's running great
MarkEmark
Car: fully-built '95 240sx KA-T
Frozen240 wrote:Go here
Wow, that website is a RIDICULOUSLY good source of information for tuning/EFI...definitely bookmark that one...
hysteria
Car: s13 kat, sv650s, and other projects
