wideband question
Jasong
I just put in an AEM wideband and when cruising it is constantly ranging between 14.2 and 15.7. It does it so fast its hard to read the actual ratio. When I give it more throttle it will settle to a constant ratio. Is it normal to constantly range like this?
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
Yes, your stock o2 sensor will constantly try to correct rich/lean conditions causing a fluctuation under vacume. Seeing a steady AFR level under boost is typical.
