DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Mon Aug 22, 2005 10:35 am
hmmm, i'm not tight enough to have a wideband o2 sensor, but i might be able to help you a bit from what ive gathered from my narrowband gauge, and what i can remember from my intern days dyno tuning.
you took out your old o2 sensor entirely? and is there anyway to hook up your wideband o2 to the car? is it an S13 or S14? maybe i dont understand what you have already done, but i was under the impression when you buy an o2 sensor you still have to use your old o2 sensor and leave that connected to the computer, and then you need to weld in a bung on your exhaust manifold to use your wideband o2 sensor.
the o2 sensor sees different things under different situations. it is my understanding that when cruising the afr jumps back and forth between being just rich and just lean, this is great for emissions because it basically stays stoich the entire time, or rather it has a stoich average (stoich = 14.7)
under hard deceleration, or compression/engine braking the car goes very lean, thats why it stays lean and then when you pop it into neutral it comes back up.
at wide open throttle or WOT the computer goes rich as hell and then sees its at WOT and ignores everything else and uses its own WOT fuel map. So it usually goes rich and then starts to lean up but it stays pretty stoich.
for turbo you definately want to go richer to keep things cool when youre gonna shove all that compressed air in there, so think high 11 to mid 12 to one.
i can't really tell with a narrowband gauge but if you go richer after you've driven for a while it might be an indication of something wrong, or maybe thats just what the computer does when things get hotter, like i said, i cant tell you much about that.
if i could think of anyone who could answer these questions better, and i'm sure there are a lot, i'd think deviousKA, but hes spending a lotta time at his new ecu tuning site. there a thread about it on the KA page so go visiti it, theres a good amount of usful info there
