wrong, one plug goes to the monitor and the other one goes to the new 02 sensor, the one that comes with the kit, and yes you have to weld the bung to your downpipe. in other words you will end up with two O2 sensors in your car.DRIFTINIZ wrote:
the monitor comes w/a new o2 sensor.....do i replace my oem one w/that and then hook up the necessary wires for the unit to work?? i noticed that there are 2 plugs w/the unit and thats it, i'm assuming one goes to the actual monitor itself and the other plug looks like it would plug right up to the plug in my engine bay (the plug where the original o2 wiring plugs into)
thanks
ok....when i unplug my oem o2 sensor from its clip......i can't just plug in the new harness and new o2 in right there......and then just plug the monitor in and be good???.....or is it pretty much that the original o2 cannot be replaced w/the new o2???....mallbor240SR wrote:
