compression »
https://forums.nicoclub.com/compression-u9345.html
Mon Feb 09, 2004 1:23 am
the post about them wearing out in a few months is not true, as long as you dont run leaded gas or octane over about 110.AEM uses a bosch sensor, which come as OEM equipment on some cars. No OEM uses a sensor that wears out in a few months.Here are some notes from the AEM wideband sensor instructions:_________The sensor contains a ceramic module and should not be subject to mechanical or thermal shock or it may be damaged.The sensor is not designed for operation on leaded fuels, doing so will dramatically shorten sensor life.Long term running in the rich region (Lambda < 0.95) will shorten sensor life.High exhaust temperatures (over 850C) will shorten sensor life.Engine oil consumption at a rate greater than 1 quart per1,000 miles will shorten sensor life.Do not run the engine with the UEGO sensor installed without power applied to the controller and the sensor plugged in.-----------------
