wideband or what?
hek1620
Car: '89 240sx
i'm hearing now that widebands don't last. so how can u keep an eye on ur a/f? i'm going to be running 550's with an safcII. 10lbs. stock motor. is it neccessary? thanks.
codyace
Car: S14 w/redtop
I've not EVER had bad luck with my wideband, nore has many of the close friends I have...we all have different setups (turbo tiburon, turbo vr6 gti, 4g63 swapped colt, built 1.8t GTI, Turbo RSX S...etc etc) We've all had ours now for at least a year (with the exeption of the RSX) with no problems at all.
MazworxRaceSupply
hek1620 wrote:i'm hearing now that widebands don't last. so how can u keep an eye on ur a/f? i'm going to be running 550's with an safcII. 10lbs. stock motor. is it neccessary? thanks.
you will go through a o2 sensor here and there but for the most part they hold up well - check out innovate motorsports line of widebands (www.innovatemotorsports.com) - they are nice setups and a wide array of options to suit your needs
the replacement sensors for their systems are relatively inexpensive as well which is nice
