x2 here. I got the display for it and the EGT probe, Still need to get the 3bar map sensor.eh? wrote:I have the zeitronix wb02. It's probably the cheapest but it packs more per $. Some wb02's have the ability to output a narrowband o2 feed for the factory ecu, so you have the option of just removing and replacing the stock wb02.. Just check out the specs of each.
where did you guys install the wb02? add a test pipe with a bung? you guys that have it, how did you do it?dsm wrote:zeitronix is on of the best and you can log several things with it. However, you can't put a WB o2 in the stock location because it is too close to the high heat and will fail faster than normal. Almost all brands will say to put the sensor at least 24" from the head or turbo, some even say 36.
