Wideband O2 Systems!!!
Pornflakes
A lot of people have been asking about them, so here's the COMPLETE system including O2 sensor for dirt cheap. www.ka24de.com
4felix20
Car: Emerald Blue S14
awesome.
KApwr
Damn Pornflakes, we just ordered one right before you posted!! Still got alot of stuff from you though. Thanks for supporting the beloved KA. Keep up the good work.
TurboKA37
yea thats a good deal. i like how u can switch it over to a 1V reading so u can use it for the narrow band reading for the ecu.
Pornflakes
TurboKA37 wrote:yea thats a good deal. i like how u can switch it over to a 1V reading so u can use it for the narrow band reading for the ecu.
You can do both simultaneously; wideband reading and 0-1V narrowband reading. That way you can feed the narrowband signal to the ECU, while you tune with the wideband.
TurboKA37
If you know how to solder and put chips together id check out the tech-edge DIY kit. you can pretty much get everything including wires, computer, and display for about $150. you just have to take the time to solder everything together. this is prolly what i will get.
Pornflakes
The TE unit does not work with all sensors such as NTK, etc..., but only with the Bosch LSU4. Also, the TE unit is not able to self-calibrate like the LM-1 unit can.
In addition, the TE DIY is $251 (not $150) with the display, O2 sensor from VW, connector, and WB unit with cable. Then you have to solder it together. There's a significant chance for problems if you're not experienced at this. Then you have to calibrate it.
There's just too much room for error in my opinion, and it's a long wait to receive the unit from Australia. The TE ready-built unit would be much better then the TE DIY unit (for the unexperienced) , but then the cost is high too.
For $349 shipped, the LM-1 is a self-calibrating, complete system that is fully built in the factory. Is is complatible with ANY wideband sensor. Also, the LM-1 was actually compared side by side with the Horiba WB system (which costs a few thousand dollars), and it was absolutely DEAD ON accurate with it.
huguetpj
Car: 93 KAT Coupe
Pornflakes wrote:For $349 shipped, the LM-1 is a self-calibrating, complete system that is fully built in the factory. Is is complatible with ANY wideband sensor. Also, the LM-1 was actually compared side by side with the Horiba WB system (which costs a few thousand dollars), and it was absolutely DEAD ON accurate with it.
I'd purchase the unit if I just had the cash. I'm pretty sure it'll pay by itself from not having to pay dyno time everytime you tune your car.
drftnassmofo
Car: 84 s12 ca18et-TRADED
85 s12 ca18et-SOLD
92 fastback-SOLD
91 fastback-SOLD
90 coupe KADE swap-SOLD
06 Infiniti M45
i want this to be my next mod but how much horsepower can i get out of a stock 91 ka24de with the kit???
