VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Mon Aug 02, 2021 4:31 am
The functional behavior is completely different. A/F's have a "center" voltage around 2V and give a pretty much instantaneous rich/lean indication, which is why they're typically used at the front for mixture control. HO2S's have no set "center" and are manipulated temporally by the ECM to analyze catalyst efficiency, the ECM makes slight rich/lean adjustments on a cyclic basis and watches both the voltage swing and response time of the sensor. Thus, the firmware algorithms to drive HO2S's are very different (and much more complicated) than the the firmware for A/F's.
