Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Mon Dec 05, 2005 5:36 pm
You already have a decent base map, don't you? The calculated values for your 440's, should get you to the dyno. If you have a map good enough to put it on a dyno and start tuning, then you should be able to drive there safely. Just make sure you stay below 3000 rpm and don't drive it hard. Might be a good idea to let it warm up good first, also. Then the closed-loop will take over and hopefully keep you running right around lambda = 1.0.
How far away is the shop with the dyno?
