float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Mon Dec 07, 2009 7:00 pm
Reads fine there. I used to have it right before the cat, but when I would do a pull, it would log the AFR in the next RPM range. It also seemed to make my closed loop a little jerky. I moved it up to the stock location, my AFR's logged in the right RPM range, my closed loop was much smoother, and I've never had any problems with sensor longeivity. I think my sensor has like 30K miles on it. 15K of that is with ethanol though, so, IDK if that makes a difference.
