wideband install
Beems240sx
Car: built S14, E30, R6 raven
i just picked up an AEM UEGO. i was talking to my friend and he suggested i take my stock 02 sensor out, put the wideband in there, and tap the signal wire from the engine harness to the wideband. would this work?i was searching and i found that you want it about 36 inches down the exhaust.
pauliedrft
Car: 91 240sx
Add another bung and go to there web site it will tell you were and how far to put it down stream from turbo .if you have a aem ems you can if you tune it for the wide band .which you can find that info on there web site also .
kainvamp
Car: '91 Sil80 w/ SR
i dont suggest replacing your stock O2 with the wideband, just get the bung welded near the end of your downpipe.
