If you are in the market for any Wideband or Electronic product message me. We are a supplier for every Major brand in the automotive community. We carry products from AEM, PLX, Innovate Motorsports, Greddy, HKS, DEFI, Blitz, and many more. EMAIL OR CALL ME FOR BEST PRICING. Innovate Motorsports We have ALL Innovate products on sale. LM-2 -- Basic Kit retails for $349. The new LM-2 "Basic" Kit (Single Wideband O2) ONLY includes the LM-2 meter, Bosch wide-band oxygen sensor, 8 ft sensor cable, cigarette-lighter power adapter, USB cable for PC connection, weld-in bung and plug, LogWorks software CD, and quick-start guide. DB Gauges in Red or Blue retails for $229. The industry's most accurate and fastest responding wideband controllerOne additional analog outputEasy setup and wiringLC-1 includes Innovate serial in and out for adding additional modular tuning system (MTS) componentsBlackout appearance when not poweredLog directly from the LC-1's digital output into laptop with included softwareIncludes LC-1, Oxygen Sensor, O2 Bung, and of course the blackout DB gauge XD-16 retails for $329.
The XD-16 ships as an Air/Fuel Ratio gauge, but can also be configured to display any channel in the MTS chain or it can be connected to the LM-1. The XD-16 features programmable LED colors and a remote control button to start and stop log sessions, initiate calibrations, or view min/max values.
- 2 Bezels + 8 faces = 16 combinations (see below)
- 3/4” thick, so it's possible to mount even in surface mount configurations
- Fits 52 mm (2-1/16") gauge pods
- 3-character LED display
- Record/Calibrate/Peak Hold button
- Programmable (values and colors) digital needle
- Billet Aluminum bezel
- The basic kit ships with both black and silver bezels, 8 faces (AFR, Pressure, Temperature, and blank).
- MTS compliant
The XD-1 can be customized via a Web Based print tool. You can choose any unit of measurement, various fonts, upload an logo (or other graphic), and then print the high-resolution scaled image directly onto transparency paper. Use you included blank faces, overlay the clear cut out, and you've got a custom gauge face! [LEFT]The XD-16 is also a key component of Innovate Motorsports' Modular Tuning System (MTS). Using the XD-16's serial ports you can daisy-chain other Innovate devices such as the LC-1, AuxBox (LMA-3), DL-32, TC-4, and SSI-4.The XD-16 Gauge System can be purchased separately for $229 as an accessory to be used with the LM-1 or with any of our MTS compatible units. This kit includes the XD-16, mounting hardware, serial cable, CD and quick-start guide.This Standalone Gauge Kit comes complete with the patented award-winning LC-1 Wideband Controller, XD-16 , Bosch 5-wire Wideband 02 Sensor, Bung/Plug Kit, Software CD, and quick start guide.[/LEFT]Installation and SetupInstallation of the XD-16 is relatively simple. Complete documentation is supplied, and the support pages, user forum, videos, application notes, and tuner resources can also speed you on your way to effective tuning. G2, G3, and G4 Gauge Kits G2 AFR Gauge Kit The G2 Air/Fuel Ratio gauge (52mm, 2 1/16”) features a high-speed stepper motor, through-dial backlighting, and an illuminated pointer. Each kit includes the gauge, an LC-1 wideband controller, oxygen sensor & bung/plug, and the award-winning LogWorks engine-tuning software. Key benefits of the “G2” kits include: - The industry’s most accurate and fastest-responding wideband controller- One additional available analog output (one connects to the gauge)- Easy set up and wiring (instructions included)- LC-1 includes Innovate serial in & out for adding additional modular tuning system (MTS) components. (Gauge itself is analog only- no serial)- Illuminated needle and through-dial backlighting- Log directly from the LC-1’s digital output into laptop w/included software G3 AFR Gauge Kit Innovate Motorsports is releasing a new 52mm (2 1/16”) gauge- the “G3” Air/Fuel Ratio gauge. The G3 features a high-speedstepper motor, through-dial backlighting, an illuminated pointer, and retails for $289. Each kit includes the gauge, an LC-1 widebandcontroller, oxygen sensor & bung/plug, and the award-winning LogWorks engine-tuning software. Key benefits of the “G3” kits include: - The industry’s most accurate and fastest-responding wideband controller- One additional available analog output (one connects to the gauge)- Easy set up and wiring (instructions included)- LC-1 includes Innovate serial in & out for adding additional modular tuning system (MTS) components. (Gauge itself is analog only- no serial)- Illuminated needle and through-dial backlighting- Log directly from the LC-1’s digital output into laptop w/included software- "Blackout" appearance when unpowered G4 AFR Gauge Kit.The G4 gauge kit contains the same componenets as the G2 and G3 kits with the updated G4 Gauge. *********** AEMAEM UEGO Retails for $388.75. AEM’s Wideband UEGO Controller is also available in a gauge that includes a single-channel analog output with a Bosch O2 sensor in one unit! AEM’s Gauge-Type Wideband UEGO Controller features an LED readout and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere. No laptop required for monitoring! Key Features: • Bosch sensor included!• 24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio AFR• Integrated three-digit display reveals AFR in real time• User-programmable 0-5v analog output included for use with data loggers and ANY engine management system• Ideal AFR monitoring tool for carbureted applications and engine dynamometers• Does not oscillate AFR like narrow band sensors• Serial data stream included for output of AFR (RS 232)• Accurate to 0.1 AFR AEM Tru-Boost gauge type controller retails for $419.50. AEM’s TRU-BOOST Gauge-Type Controller is an electronic boost controller that combines the simplicity of a manual boost controller with the added ease of adjusting boost levels through a gauge interface. There is no external interface required for set up, and it is fully functional right out of the box. There are no gimmicks or special software programs included. If you want more boost press the button on the right of the gauge face, and if you want less boost press the button on the left of the gauge face. It’s that simple, and IT WORKS! AEM’s TRU-BOOST Gauge-Type Controller includes everything you need, including an on-board 29 psig pressure sensor, built-in Overboost protection with two timed shutdown levels, a scramble boost setting and a low-side output for a warning light. AEM offers a 75 psia boost sensor for high boost applications (sold separately). AEM’s boost control solenoid (included) is the only one specifically manufactured for automotive boost applications, which means it won’t corrode and stick from exposure to rich fuel mixtures, it is pressure tested to 100 psi and includes -4 AN fittings to eliminate any chance of leaks. For Unbeatable Pricing Call or Email Me Today.
Regards,
[email protected]
