Ok, what do you like and don't like about the LM-1?Good points and bad, if any.SeVa-S13 wrote:Carl, they CAN come with the same AEM UEGO mentioned here as an option at additional cost -- Hence the part numbers like 30-1611 and 30-1611(U).
I have an LM-1 but never used the AEM unit so I can't help...
That's not true.. it's easy to set up any WBO2 with the AEM. The uego is a waste of money when something cheaper like an LC-1 will do the same job.Carl H wrote:huh if thats the case the just go with that, again why buy something redundant.besides with the built in aem one you can be assured you can use it with the aem software and it will work with the setup.
Tech edge has some of the best prices Ive seen, though I havent looked at widebands in a while.Carl H wrote:oh, huh i didnt know that.if he is just looking for a wideband controler why not look into the tech edge series, ive got a 2a0 and it works wonders.
TechEdge used to be a good deal before the dollar went south. Now the exchange rate is so bad that even the basic TechEdge kit costs more than the LC-1. Also, TechEdge uses some stupid calibration scheme that is totally unnecessary and is not required for most other widebands.IWannaS15 wrote:Tech edge has some of the best prices Ive seen, though I havent looked at widebands in a while.
I use both of them all the timeWykid 240 wrote:Hello all. I'm wanting to get one of the two. The AEM UEGO or the LM-1 wideband. . . . I've seen both and am more leaned towards the LM-1 becuase I know that it is digital. Is the UEGO digital too? The car it'll go in is a '90 240 with a RB25 w/bpu's. Also getting the AEM EMS and MSD DIS4.
-Jeramy
Actually your wrong therehttp://www.innovatemotorsports...1.phpLM-1 does make digital guages for their wideband systemsonefastrb26 wrote:
- no gauge readout
AEM - does not read under 11.00 afr its like 10.5, but the aem ems goes below. thats just the gauge+ easier to setup in the ems software+ easier to install and calibrate
Innovate LM1- big bulky box+ full calibrateable output, so works really good with aem- no gauge readout
Innovate LC1+ fully calibrateable gauge ( colors and digits)+ really easy to see, not like LM1+ works VERY good with aem ems- kind of pain to setup properly, but once it is done, it is awesome+ gauge is thin and light, so really easy to mount
We have been installing a lot of LC1 kits lately with AEM and Autronic ecus.
