XTCshri2222 wrote:I work in autobody and autoparts, and i'm always tring to find alternitive parts.I was checking threw my stock on O2 sensors and I was looking for factory widebands.
Is it possible to wire in a factory wideband 02 sensor? I found mostly 5wire sensors, one were univeral application, but you can always cut and splice.
Depends you could wire up the wideband so that it reads in a Narrowband fashion. But than again what the hell would be the point just get a regular O2.
If your asking can the ecu use a wideband in a actual wideband purpose than NO. 2 reasons wideband is a 0-5v signal where as the Narrowband is 0-1v. What this means is that the ecu can only interpret that 0-1v signal. 2nd reason is the ecu doesnt have a controller which is pretty much what heats up the sensor, calibrates it etc etc.
So other than using the wideband as a narrowband the answer is no.
