StricNyne »
https://forums.nicoclub.com/stricnyne-u10935.html
Thu Oct 23, 2008 6:49 am
so i have an egt gauge as well as a wideband on my car, i have cyc one tapped for the egt to get most accurate reading possible, now for the wideband i have a couple choices one is that since i am using twins, and cyc 1 is my leanest cyc, i could use the o2 sensor bung on front dump, and thus very accurate reading, number 2 : it came with a bung so i could just tap into downpipe, number 3: i could use rear dump o2 bung, which would be most accurate to use ? i would assume either one right off the dump, but i was also told that heat can kill a sensor and i would imagine thats gunna be second hottest part of my exhaust system any suggestions ?
