J-Spec Tuner wrote:Say this to yourself 1000 times:
Traction depends on rubber compound, not tire width
Once done, repeat as follows:
"Contact patch area is a function of tire pressure and weight."
It goes with J-specs quote.
as for HashiriyaS14..
dude..just....dude...
QUIT IT.
You're talking about adding a massive ammount of unsprung, and (even worse) rotational mass to the car, with no power to compensate....
Much less, keeping your suspension geometries, hub stress, scrub radious, and a host of other things even nearly correct....
then to top it all off, you're talking about using SPACERS to make it all fit... (search around on my own, and SMithSR's allong with others stances on this and formulate your own opinion)
please. Put the crack pipe of "I want wide wheels" down.
also
"I think the bosozoku wheel look is cool."
Really? I think it wrekcs hub bearings and put undue stress on your suspension, and decreases your spring and shocks ability to propperly control the road and steering inputs.
Still think that's cool? Knock yourself out, I'll be passing you on the inside of ANY turn.
If you're still hell bent on wide wheels...that setup may clear, depnding on your tire size. To be safe, you may need to run a +20 front...
ANyways. Bleh. I'm too tired to start this debate over again. SUffice to say, if you want wide wheels for the sake of wide wheels..knock yourself out, and send me money..because you obviously have more than enough disposable income.
FOr the orional thread starter, ChMercer is correct, if you already ahve s-03's..get the same, if not better, a tire on the new wheels..you may notice a bit of improvement..
search around, theres an adctive thread (and a faq) on tire widths, and other things that will explain it all.
-Chet
