chmercer »
https://forums.nicoclub.com/chmercer-u5648.html
Fri Mar 24, 2006 11:45 pm
you can run whatever size wheels you want basically. front you are limited by the steering ie scrub radius, eventually you get so much scrub radius that you have to widen the fenders in front and behind the well instead of just at the top to clear. that is at extreme levels though so no worries. rear is easy since it dosent have to turn, only go up and down. on my rear setup i could run 19x15 -19 with an arch flare, when you stretch 355s thats pretty much the max for DOT tires, beyond that you can run hard rain slicks to maintain streetability, these go up to like 16 inch wide which you could stretch on a 19x18 ccw if you wanted.
