TIMELSS_vert »
https://forums.nicoclub.com/timelss-vert-u41230.html
Mon Apr 26, 2010 8:17 am
The first picture is a car owned by a member on here, so maybe he'll chime in, but, you can see he has a slight roll on his fender. Personally, I think the sidewall on those are a bit tall, but that is purely personal preference. He is probably running like a 225 or 235/50/16 or something like that on an 8" wheel with the 3.5" lip they offer. You can also cheat the fender issue if you don't mind having a little bit of negative camber, so the top of the wheel is pull in, and the bottom is pushed out, i.e. //-----\\. There is a thread on Zilvia called Max tire thread in the chat section, check it out for other peoples' setups and that should help point you in the right direction.
