it comes with everything but the lcd display screen for $279. can you just use a laptop to display the data? i really dont want to pay over $100 more for the display screen.K240 wrote: http://www.zeitronix.com/Products/zt2/zt2.htm....
with the boost sensor, EGT sensor, and lcd screen, you have all of the guages, and you wouldnt need other guages...thats like a 400 dollar savings, WOW! /end advertisement...
the boost and egt sensors arent included for the 279 either, but yes, you can output the data to a laptop with a real time display or datalog plot. it also has a wideband analog output you could send to a properly calibrated gauge.daniel240 wrote:
and the resolution is higher too. a narrowband reads lean from 0v to about .2v, stoich from there until about .8v and the remaining .20v (0-1v resolution, mostly in the stoichometric range) while a wideband reads a linear, for the most part, 0-5 volts (I think the new bosch/vw's everyone uses now may only read to 3.2v).skatanic28 wrote:its a sensor/controller combo used to monitor/log your air/fuel ratio. its better than the stock narrowband sensors because it covers a greater range of ratios (usually from 10-21) instead of just right around stoich. they come with a wideband oxygen sensor that you add before the cat.
its just a monitoring device, you still need fuel management (safc/retune/emanage) to tune with. but it makes it much easier being able to datalog on your own and stuff.
