Wide band O2
nb07bcar
When everyone is talking about a o2 sensor are they talking about an actual o2 sensor or the box that tells you what you o2 level is. I looked up wide band o2 sensor and all it came up with is a box that reads the o2 signal? Is that what you mean by wide band o2? And if so, why would anyone buy one of those thing? Your paying $300 for a volt meter??????
Gutling
Car: 1989 Nissan 240sx SE
A wideband o2 sensor kit should come with a o2 sensor and a box that goes inside. it replaces your factory o2 sensor. a narrow band air/fuel gauge (what a lot of people have) just splices into your fact o2 sensor wiring and gives u a rough rich/lean reading. wideband is what u use on a dyno tune or any tune really, really precise. anyone correct me if i got something wrong.
Craving4Boost
Car: 91 240sx fastback
it is better to use the factor 02 AND the 02 from the wideband.
nb07, if you dont want to go to a dyno and use their stuff, you can tune on the streets with a wideband 02
nb07bcar
All I'm saying is that there is no such thing as a wide band o2 sensor. All o2 sensors read from 0-1 volt. The box you buy is just a volt meter. It reads the the o2 sensor voltage. Why would you spend money on it. If you have a volt meter you can just splice it in and read the signal??? Does this box do anything else???
turtl631
Car: S14
You're wrong. Go read some more if you insist on disagreeing with us. Wideband O2 sensors output from 0-5 volts and have a highly calibrated display. If you think you know enough to be able to determine A/Fs precisely from looking at a 0-5 volt scale, then you can beat the system and not buy the box.
Gutling
some cars come with a wideband o2 factory, suchs rsx-s (i just know cause my friend has one) and he can get accurate readings and tune from it by having a hondata system. when u get ur car tuned/dyno tuned with a wideband, usually they pull ur o2 sensor out and put theirs in hooked to a laptop or similar. if u got something like a standalone system, or i think the aem ems does it too, u can run ur own wideband and see/tune on a laptop.
sunnys14
Car: S14
us nissans arent fortunate enough to have a wideband from the factory. just get a wideband 02. you WONT regret it!
