Wide-Band O2 Sensor Question
200RX
Car: 1989 Nissan 240SX SR Black top
Hey Ya'll
I got a 94 SR20 Blacktop and was wondering if I were to get a Wide-Band O2 Sensor Kit should I put it in the Cat Conver or the Turbo Elbow? Also shuold I still run 2 O2 Sensors or should I plug one up?
Thanks!
If ya'll have any setups that work out for you, please share
Emperor_Tha
I got the stock o2 sensor on the elbow and my wideband is on my downpipe about 3 inch away from where the pipe bend to turbo
200RX
Nice Emperor, sounds like a good idea to me. I assume that if I put my Wideband in my Cat nothing crazy will happen.
Emperor_Tha
u will get a leaner reading if it's in cat or after the cat as I assume u r running an actual cat and not a straight pipe
rb25xtc
Car: 1991 240SX Coupe
200RX wrote:Hey Ya'll
Thanks!
You want the O2 sensor 18 inches downstream of the turbo, but before the cat. You want it mounted at or above 9 or 3 'o' clock in the piping.
Modified by rb25xtc at 12:43 AM 9/28/2008
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
Is that a cut out on that exhaust? I always wanted to do that and keep the stock cat-back. I like how you hid it, pointing under you're car.
How does it sound? Smooth, raspy or really F-N loud?Do you feel a torque loss?
200RX
Woo Go RB25, thanks for the help.
So i'm gona assume that I plug my Cat one up and bung a new one in the downpipe?
I wana get a SAFC to get that control so If this changes anything let me know
Modified by 200RX at 8:38 AM 9/28/2008
PhopsonNY
I would modify the above by saying you need to mount it at he 10 or 2 o'clock angle in the piping to prevent any condensation from collecting in the sensor and killing it.
good luck
