wicked tunning subframe collars DIY
dat925stunna
Car: 90 hatch s13
ok i wanted subframe bushings for the longest now to eliminate wheel hopso i purchased these subframe collars from ebay made by a company called wicked tunning...
they come in a nice finish
ok these things are slotted so you dont have to bring the subframe downthey also crush your existing bushings to make a solid bushingyou'll need a 12mm socket,and a braker bar,a 11/16 socket and a jack of your choice
start by jacking up the car then removing the two 12mm bolts then wen you remove the 11/16 nut the corner of the subframe should come down an inch or so that should be enough to slide in the top collar/bushing in
then put that piece held by the 11/16 nut back in then tighten till you cant no more thats wen you know your done...and jus repeat 3 more times till you cover all four corners
Modified by dat925stunna at 5:32 PM 10/12/2009
Modified by dat925stunna at 5:37 PM 10/12/2009
Modified by dat925stunna at 5:39 PM 10/12/2009
LOVERboy
Car: 1997 240sx se KAT
I need those too!!! ....
I wish I can get some of those ... =/ I took my stock 1 out and throw the ES 1 in ....
dat925stunna
Car: 90 hatch s13
LOVERboy wrote:I need those too!!! ....
I waz so lazy to remove my subframe so i looked for an alternative way i hope this helps anyone also
wht240sx
Car: 1991 240sx/1995 240sx
Have you tested them yet, did it get rid of your wheel hop?
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
this has deffinatly been answerd before but, how do these compare to full solid bushings or the es pineaple bushings?
dat925stunna
Car: 90 hatch s13
wht240sx wrote:Have you tested them yet, did it get rid of your wheel hop?
wow these things really eliminated the wheel hop along with my tein HR coilovers but the pros is well you got a solid rear the cons is you hear everything that goes on back there plus i have a welded diff so ya its gonna sound like if your car was gutted even though mine has full interior
DMan II-40
Car: 1995 240SX SE
I put solid aluminum bushings in my car and it really didnt make much of a difference sound wise. I put some rubber walshers inbetween the body of the car adn the bushings so there would be no metal to metal contact. Kinda like what NIPerformance.com bushings have if you can find a pic im to lazy and im at work.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
FYI - Nissan doesn't use 11/16 nuts... its a metric vehicle.
Emperor_Tha
I put rubber washer to reduce the noise.
It does not fully eliminate wheel hopbut it does elimate that floating feeling in the rear when taking corners
