santiagodraco wrote:Using a Blackberry 8830 in my G37, on Verizon. Works flawlessly with the car's bluetooth speakerphone.
I have the exact same phone. I have had the car for about three weeks now, and twice it has failed to pair with the phone. It is like the bluetooth has crashed either on the phone or in the car. I have to completely shut down the phone, remove the battery, wait a few minutes before putting it back in, and then reboot the phone. Then it will pair again and work normally. The first time it happened, I had to do everything I just described and then I deleted the bluetooth connection from the car and the phone and repaired them. I then learned that doing that erases the car's phonebook and you have to start over again from scratch which sucked major ***.
