Why Z32 transmission?
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
As I plan my VH swap I was wondering why everyone uses a VH->VG adaptor. The KA transmission will hold at least 450hp reliably so why spend the extra money on the VG.
I assume the VG transmission has longer gears? and making a KA adaptor would be about the same difficulty?
What are you thoughts? (and yes I know the VG would hold more power but I don't plan on making more than 350)
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
This is the hybrid section you may want to try the VH VG forums and talk to those guys. This is swapping non nissan engines into nissans and vice versa.
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
This is about a hybrid! nutfuzz VH45 in a 240
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
No thats a nissan engine in a nissan thats just a swap...... a hybrid is like what I have a LS6 in a 240 Nutfuzz cmon I was only trying to point you in the right direction, You suck at life.
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
I didn't mean nutfuzz as an insult! I use it a lot. think of it as a term of endearment
I still think the question applies to this forum. If you were going to put a vh in an RX-7 why use the VG transmission instead of the KA?
craigztoyz
Car: lots of unique hot rods, and customs, with modern engines, and a good truck to pull the trailer.
As one of teh people doing a VH45/Z32 swap. The greaing. The engine will easily use a Z32 clutch/flywheel/starter, so the trans is a perfect match, and for 500 they make a sweet adapter, that usually fits great.
sdzxdriver
Car: 1982 280zx
To the OP, I'm assuming most people use the VG transmission because it's stronger than the KA transmission. It can handle a higher torque load than the KA. The internals of the VG are almost the same as an RB25 transmission. A few people on a different Z forum are going the same route to use the VG transmissions on the L-series motors.
Return to “Hybrids”
