fakts13 »
https://forums.nicoclub.com/fakts13-u7234.html
Sun Jul 27, 2003 1:48 pm
14 and 13 aren't THAT lean, it's just that 12~13 is better for turbo cars... as long as you aren't detonating i don't think you have much to worry about... you're getting more power now than if you were to richen it, but you're running hotter than you normally would be. if you're stock w/ only an intake, don't worry about messing w/ fuel management. just make sure you run the highest octane available at the pumps. the extra boost could be from a worn out actuator? these motors are old.
