driftneil »
https://forums.nicoclub.com/driftneil-u60942.html
Wed Jun 10, 2009 2:32 pm
I recently swapped a newer ka motor and 5 speed into my kouki, and changed the engine bay harness to a 96 5 speed in the process. This was to allow me to use the 5 speed trans harness, and to need to have the clutch pressed to start the car. I did not swap the dash or interior harness, and think this is the problem. The car turns over, but doesnt start. I don't hear the fuel pump turn on, also pulled the fuel line off the rail and cranked it with no gas coming out. But I have power to the fuel pump fuse, and relay. So I can only assume the problem is in between the relay and the pump itself??Any one have this situation??Any suggestions?? My kouki is just sitting there....
Modified by driftneil at 2:36 AM 6/11/2009
