slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Mon Oct 18, 2004 7:57 am
^^ I'm with benemorius - did you actually measure the compression, or just assume it's there on all 4?
Have you checked the fluids? Any mixing or loss of level? How fast were you going when you dropped to 2nd? Depending the speed, you could have spun a bearing or threw a rod(reason the starter is having such a hard time). Did it smoke coming off the freeway?
BTW, what codes did the ECU throw? (you can check this FYI from a connector under the dash, rather than digging out the ECU, by shorting two pins - search for details).
Keep us posted,-Jamie
edit:: now that I read back over your post, I see the brake light came on too - this is indeed indicative of the starter, but that doesn't explain loss of power. Start with the basics, you could have bigger problems than just a starter.
