TDot »
https://forums.nicoclub.com/tdot-u191641.html
Sun Mar 09, 2014 9:20 am
Your avatar info says you two have different cars, might be different setups. I don't know, just want to make sure you too are aware of this. Unless anotheraznguy has an m37 that he didn't list. Anyway, good luck.
Edit: again i dont know what is happening, but as far as current, led really don't require much current...from the ones I've seen at least. Just look at the gauge of wire that should be feeding, and that will tell you if enough current is able to get to your led which shouldn't be more than 1 amp, two at most from LEDs I've seen. Im assuming the wire feeding is at least 16 gauge. Voltage is provided, current is drawn.
